Hey folks,
I just installed a Bully Dog "outlook" box on it. the problem I have is that it sets a Map sensor Code.
P0237 (Map sensor voltage input below the minimum accpetable voltage)
before I had this "outlook" I had one of thier "Torque Dog" boxes that had the switch that changed power settings. the Torque Dog also set the same code, which leads me to think that it might be something other than the Bully Dog thats causing the code. although... ... ... . Its never set the code before I put the Bulley Dog on it, & now with this outlook, Im running it on 0% adder & it does not set the code.
I dunno about any of the other boxes out there, but the Bully Dog products have a jumper cable that you plug the into the map sensor & then another one that you plug into the harness. I would imagine that the box tries to truck the ECM into thinking it has more boost sooner so that it will crank up the fuel. not sure, just a guess.
anythoughts???
thanks guys
Bob
anythoughts???
thanks guys
Bob
