Bully Dog question?
New EDM's
Billet valve cover!
I have the Bully Dog Torque Dog on my truck. I am going to be installing a set of DDII's soon as well as an elbow. Right now I am at 20psi of boost, when I add the injectors and elbow, will the extra boost, I am looking for set a code for the truck to start de-fueling? The Bully Dog is plugged into the MAP sensor, and I did call out to Bully for this same question. I was told "no", the chip will fool the ECM into thinking boost is below 20psi. I am still in wonder if anyone is running the same set up. I have a FASS system coming now, I like the idea of ridding the lift pump. I have read that the HX35 is able to to push 36psi, what do I need to do to at least be able to keep the smoke clean and gain more boost? Am I going the right way? Or am I a fool... ... ... . lol:rolleyes:
The map sensor plug on the "Torque Dog" should fool the ECM just fine. You will probably see anywhere between 30 and 40psi. I've heard 38psi is on the upper end of the effective range of a hx35/12 so an adjustable boost elbow would be nice but not nessasary. That turbo should keep EGT's in check and smoke clean.
I also have the torque dog chip, i have also put in a set of bullydogs 120 injectors and have had no problem with any codes being set off.
