I noticed that normally on my truck when I "bump the starter, often the lift pump will run for 20 seconds or so.
But not always. Ususally just once, then after that, repeatedly bumping the starter only produces a run time for just a fraction of a second.
When I was bleeding the lines a couple of days ago after replacing the lift pump, the lift pump would run every time I bumped the starter as in those cases there was no backpressure.
(BTW, the new lift pump behaves exactly like the old one. )
So, is this normal? I'm guessing that in normal operation, the lift pump only runs to some preset pressure, then shuts down and subsequently bumping the starter (assuming the pressure is still there) will not yield a lift pump long-cycle run time?
Shawn
Shawn
