Originally posted by turbo torque
PPillard- I've read about the pro's & cons of DI, high swirl,deep dish pistons, etc. From what I gather the key is to have the wvo at 180F - 190F (correct me if I'm wrong)
That's exactly right. Heat is the key. We use waste heat from the engine's coolant system to pre-heat and thus lower the viscosity of the veggie fuel system that we install. Cold-starting on WVO
can cause coking of the injectors and other such problems, which is why we cold-start on diesel (or biodiesel), bring the engine up to normal op temps, then switch over to veggie.
I run a 98. 5 24V that I'm itching to convert to WVO. (My original vp-44 is gone, hope replacement is stronger) If I understand right your running a 24V on wvo with no side effects,other than some pusher pump problems. Are there any other issues with the 24V Cummins & WVO? If not I'm ready.
My 24v seems to be doin' great now. I've gone almost a thousand miles with no problems. Initially, I had two problems: the pusher pump (like you mentioned), and the size of the veggie filter. Of course, I have a fuel pressure gauge on a pillar mount to costantly monitor readings.
The pusher pump was the most problematic to solve, as we tested a buttload of them to find the right one. The one we have now, which seems to be bullet-proof and is performing beautifully, was a rather pricey option, but seems to be worth the dough. It's able to maintain 17 psi regardless of what type of fuel it's pumping, or where your foot is positioned on the throttle. It doesn't matter if I'm idling or flooring it up a steep hill, the fuel pressure doesn't deviate more than a half a psi. I can regulate it to whatever psi I want, as well. It's really a sweet pump. Once I put a few thousand more miles on it, we'll release a Cummins kit with this pump in it. Won't be cheap tho.
Also, the Cummins needs a
big filter to supply the flow the pump needs to maintain a safe psi. Once we nipped those two things in the bud, the cummins and veggie started playing very well with each other, with no further need to discipline either. We were very proud parents
