SKneeland said:
just a thought, but is it possible you are spending more on fuel filters than you are actually saving by burning a couple dollars worth of oil?
That is a good question, I wondered the same thing. But keeping track of the cost has shown a net savings. Settling the oil like Steve does works. I put my used oil in a 5 gallon pail and use a lid with a built in pump and push it through a $5, 10 micron filter. The filter assembly is $25 shipped but you have make a bracket (took 10 minutes).
The added benefit is the lubricity of the oil as well as reduced fuel costs (little).
Steve has a filter on his truck the same size as mine and he gets 25k miles out of each filter.
I have a Vulcan big line kit, relocated OEM pump pushing into a frame mounted, 10 micron, EASY_TO_CHANGE $5 filter. Life is good.
I ran used motor oil and/or two cycle oil for 90k miles on my old 01 and it ran like a sewing machine when I sold it.
The current problems I am having with my VP on the (used) 01 3500 I bought vanish when I run 75:1 on the mix. My feeling is that since the problems go away with lots of oil in the fuel, the VP internals are somewhat galled from the dry (low lubricity) junk the EPA makes us use. The refineries add a light oil to the fuel to compensate. But get a batch of diesel that is low on added light oil (at the refining level) and, drum roll, internal timing failure.
I saw a thread some time back on autopsies on dead VP's. Many of them had seized rotors and galled pumps. Geee, I wonder why?
Adding oil to the fuel makes sense even if you didn't save any money.
JMO
