OK, I searched on this for quite some time... and find it very funny that there is nothing conclusive... in fact, running used oil in a CTD was ridiculed not even 3 years ago, and now it is more or less accepted in the 1st/2nd gens!
My question is this:
Who has ran used MOTOR (waste/drain) oil through their 3rd gen? Pros/Cons? Problems?
Now don't get me wrong, I'm only going to run oil that I know where it came from (my cars and truck) and it will be filtered at least three times (oil filter on the car/truck, 10 micron filter on the "oil tank", and finally through the HF6604, 3 micron FASS filter)...
And I'm not going to run a high percentage, probably try to keep along the lines of the 5% Cummins recommends. (rounding to 40 gallons, 5% would be just under 2 gallons of oil per tank?)
As far as the filtering goes, I figure that anything in a "clean" fuel that would pass the 10 micron filter (in a normal OEM fuel filter setup, not running waste oil) would cause as much damage as anything in motor oil/fuel filtered at 10 micron... or am I missing something??
And again, I'm also filtering down to 3 micron on the FASS too... which will also do a fine job of keeping the oil stirred up too...
So, who has done this and what effects have you seen??
steved
steved
