It’s time for my annual cry for guidance from you guys “the Dodge Ram experts”!
After returning home from a recent snowmobiling trip (~325 miles) with my truck/trailer all systems were functioning just great. I unloaded the truck, took it for a wash and then parked it in the garage - again all was good. 1 week later I looked under the truck only to find a pool of oil about 2 feet in diameter. It was definitely power steering fluid. All of the hoses and hose connections look to be in good condition and are clean and dry. No apparent leaking where the pump mounts to the reservoir housing either. It appears to me that the oil came out of the top of the reservoir at the cap!
Before this trip I checked the PS fluid level and found it to be just a hair above the full/cold mark where I like to maintain it. Oddly enough, after the burp the level in the PS reservoir is almost at the top! I had switched out the OEM PS fluid in 2007 @ 233K miles w/ Valvoline SynPower because the brake booster lines were pulsating (Brake Booster Hoses from PS Pump are Pulsating & Noisy ).
At this point I am thinking that I will suck out all of the oil I can from the reservoir and then add Redline Synthetic PS Fluid #30404 which seems to be the popular option from what I can tell and then see what happens. Could I be developing an issue with the brake booster system? What would cause the oil in the PS reservoir to burp out? Is there anything else I should be looking for?
I haven’t run the truck since I returned from that trip a few weeks ago and I probably won’t have time to dig into it for a few weeks but I first wanted to consult with you guys for a diagnosis & repair strategy.
Thanks in advance for your guidance & direction.
