i found a '96 2500 ext. cab a/t 4x4 loaded with all options for sale at a lot. they were asking 15,900 for it. after test driving it, it kinda wandered a bit, the brakes seemed alittle jumpy when coming to a stop, and if you were sitting at idle with the truck in gear, the ac on, and you turned the wheel, the ac and power steering pump would load the engine down so much that if i tapped the go pedal, the rpms would go up just like they were supposed to, but when i left off the pedal, it would be so loaded by pwr steering and ac that it would die. I said i would only give em 13,500 for it. KBB prices it at 13,555. What do you guys think? Is this worth my money? The 4x4 works too. Fires right up, even after it dies. Once you get going and the rpms are up, it runs perfectly. Almost like the idle is set too low...
jaynes
jaynes
