Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
Buzzer on a right turn
Aftermarket shackle
Transmission
This morning the buzzer did not sound when I opened the door with the key in the ignition.
Later today the buzzer started sounding at times while I was driving. After figuring out what the noise was, I noticed it would sound when I moved the wheel to the right.
:eek:
It's not on solid, just intermittently, but sounds when I move the wheel to the right.
Everything else seems to be working ok as far as I can tell.
Anybody been thru this?
:confused:
Help!!
Jay
I had some problems a couple of weeks ago with my buzzer too. It would sound intermittently and also stay on, with the sound getting louder and softer. It was very annoying and made me :mad: so I didn't spend too much time locating the problem. I grabbed a hammer :eek: and gave the driver's door switch a couple of whacks after spraying it with some lube (the switch, not the hammer :D ) Buzzer works fine now :D
Sean
Sean,
Funny you should say that!:D
I sprayed the door switch yesterday with a "liberal" dose of WD 40 and worked it several times.....
It didn't screw up today on my way to work so perhaps it's fixed?:confused:
Could I possibly have fixed it without a 'persuader'?:eek:
Thanks for the reply.
Jay
