by pass filter adapter
swapping rear axles
Dually tire pressures - different PSI for improved wear?
MLee
Not meaning to start a new thread on by pass filters, but I have made an adapter to work with the FRANTZ filter when you use the SCOTT TT. The tube is larger than the frantz roll, and needs to be adapted some how, by "O" ring or something to make the area around the stand pipe snuger to get the needed oil filtration. If you are inrested go to my rig pictures and see what and how I did it. Just takes a little time and patients to fit the tube, size wise. I also used one "O" ring upon re-assembly, this went toward the bottom of the stand tube to centre it.
Marv.
