Hey fellas, I'm about to purchase an oil bypass filtration system. I'm going to put the return going to the valve cover and will drill and tap it to except the 1/8 npt fitting. Do you guys know the drill bit and the tap thread to use for a 1/8 npt?
Also I want to install a petcock for oil sampling... . where is the best place for this? The return to the valve cover after filtration? The incoming pressure from the engine before filtration? Just curious so I know what fittings I need. Thanks
