C-Code A7 ?
Check engine light
transmission Temp Gauge Question
The other day I was pulling a car out of the snow and my ABS and Brake lights came on. The car was high-centered so I had to rock it a bit. I really didn't think anything of it because I shut it down and fired it right back up and the lights were out. When I got home I cycled the key 3 times and no codes, but when I held the trip counter and cycled once I got this:
C-Code
A7 00
00 00
I can't find anything on here even close to that. Any help would be appreciated. Just curious. :confused: Thanks in advance.
when you were pulling the car out did 1 or more of your tires spin? could be a wheel speed code since one was spinning and the others were not.
I got stuck in the snow one time and mine came up with those codes too. I never saw it again. After 9 starts it should go away unless the problem persists.
Scotty
Thanks for the reply guys. I would have responded before but my subscription had run out. Anyway, CBrahs, there were at least 2 spinning because I was in 4wd, but not that fast. I am not sure how fast is too fast, or if any difference is too much. It has been a little over a week now and the code is still there. Is this a code that would register if I went to a parts store and had them scan it? If not does anyone know where I can find a list of codes and their translations. I just don't want to go to the dealer unless I have to, because I don't want to mess around with putting the cat and muffler back on just to have them tell me that it's nothing big and clear it. Thanks again for ya'lls responses.
HD,
On my 04. 5 to run the Instrument Cluster diagnostic you make sure the OD display is on total miles, not trip miles. Turn key to on position and push and hold OD/Trip button down until instrument cluster go banannas with lights, etc. When it is done it will display any Instrument Cluster Trouble Codes on the OD display just like DTCs. It will display 00 00 when finished displaying any set codes. The display format of the cods is xx nn, where xx is the code and nn is the number of times the key has cycled after the code was set. I think that is what the number is referring to anyway. Here is a list of the Instrument Cluster codes that I got out of my DC diagnostic manual.
Instrument Cluster Diagnostic Trouble Codes
01 Airbag warning indicator output circuit shorted
02 Airbag warning indicator output circuit open
03 ABS indicator output circuit shorted
04 ABS indicator output circuit open
05 MIL indicator output circuit shorted
06 MIL indicator output circuit open
07 Wait to start indicator output circuit shorted
08 Wait to start indicator output circuit open
0B BTSI output circuit shorted or open
0C PRNDL switch input circuit shorted
0D PRNDL switch input circuit open
20 Panel dimmer input circuit shorted
21 Panel dimmer input circuit open
22 Headlamp switch input circuit shorted
23 Headlamp switch input circuit open
24 Turn hazard switch input circuit shorted
25 Turn hazard switch input circuit open
26 Panel illumination output circuit shorted or open
27 Courtesy/dome lamp output circuit shorted or open
28 Glovebox/map lamp output circuit shorted or open
29 Cargo lamp output circuit shorted or open
40 Wiper switch input circuit shorted
41 Wiper switch input circuit open
42 Wash/beam input circuit open
60 Passenger door lock switch input circuit shorted
61 Passenger door lock switch input circuit open or short to voltage
62 Passenger door lock switch input circuit stuck
63 Driver door lock switch input circuit shorted
64 Driver door lock switch input circuit open or short to voltage
65 Driver door lock switch input circuit stuck
66 All door lock output circuit shorted to ground or voltage
67 All door unlock output circuit shorted to ground or voltage
68 Driver door unlock output circuit shorted to ground or voltage
69 Passenger cylinder lock switch input circuit shorted
6B Passenger cylinder lock switch input circuit stuck
6C Driver cylinder lock switch input circuit shorted
6E Driver cylinder lock switch input circuit stuck
80 Incorrect odometer value found
81 Remote radio switch circuit high
82 Remote radio switch circuit stuck
A0 Internal module FLASH memory checksum failure
A1 Internal module bootloader failure
A3 BATTERY voltage open
A4 Ignition RUN/START circuit rationality check
A5 TCCM messges not received
A6 Ignition UNLOCK circuit rationality check
A7 VIN checksum error
A8 VIN previously stored
A9 PCI Bus internal failure
AA PCM messages not received
AB TCM messages not received
AC ABS messages not received
AD FCM messages not received
AE ACM messages not received
AF SKIM messages not received
B0 RKE fob battery low
B1 RKE module communication link
B2 Cluster mismatch
00 DONE
JV, Thanks for the list. Do you have any idea what a VIN checksum error is? I cannot find a thing anywhere on the internet. Thanks again.
Bert
My "guess" is that it was just a momentary glitch unless it keeps comming up. Get same type of related P-Trouble code occasionally. Usually does not mean anything. If it is a real error of that type you would know for sure.
