This is my first year having to do a smog test for my 2003 HO diesel. The test failed due to an error code, (P2607) the attendant could not tell me what it means, just get it fixed and take the test again, but said after fixing the problem, you have to drive 100 miles so the computer will turn off the code. Can't the auto repair shop after fixing the problem turn off the code?
After doing a search here I see that P2607 means "Intake Air Heater Relay 2 Low" In the cold mornings I do notice that the heater grid works, cycles. So does this mean only one heater is working ? The heater grid is between the manifold pipe and the head right ? Where is the other heater, or are both in that location ?
I guess I should look at the heater grid relay connections, spray clean and blow out for better continuity ? Any other areas to look at, like fuse panel ?
