Cab bolt torque
Overload springs
overloads? factory OEM?
Can someone tell me what the torque requirrements are for the cab bolts when installing step bars. This info isn't in the instructions. Tnx.
When I put my Lonestar Running boards on I think I torqued them to 75 lbs. They did not seem that tight when I took them out.
There metric bolts. You can get the numbers off the bolt head and get a torque chart and it should tell you. I was gonna do that but I forget.
Here is the metric bolt torque chart
http://www.dodgeram.org/tech/specs/bolts/M_bolts.html
On my Westin wheel to wheel bars it specs 60-65 ft-lbs. (These use front cab mount bolts and at the rear, cargo box bolts. ) The repair manual specs 60 ft-lbs for the cab mounts and 80 ft lbs for the cargo box mounts.
Bob
