cab & brake light
Fording water depth
seat belt not retracting anyone else??
cab controller went out pulled the fuse but the brake & abs light stay on. Is there a simple way to turn these lights out they will not put a inspection sticker on with these lights on
Yes I remembered that after I posted but had to go to work.
Specifically you need to set the pinion factor (tell it what rear end it has) and set the tire size (in revs per mile).
