Cab Clearance Light Install??
TDR Merchandise
Whacked the passenger side mirror...
Just purchased OEM cab lights for '06 truck. Instructions say to remove front portion of headliner to install. Can anyone tell me how to remove the headliner especially from around computer and temp display to allow this install. Any help you can give would be great.
Yeah first remove the two pillars unscrewing the screws above the handles then pry and pop the lenses out of your map lights on the temp display console and there should be two bolts holding it in place. then there are 3 screws on each sunvisor. then the visor clamp, the best way i found to do this was to use a small screw driver and pry the clamp from the side until the locking mechanism releases:Not quite sure how the dealership does it.
On my '06, I did not have to remove the lenses... . After removing the 2 pillars, just remove single screw by windshield and pull down, the whole overhead comes down together.
