2nd Gen Non-Engine/Transmission Cab corners
starring
I have a 95 2500 standard cab that I am in the process of repainting. The cab corners are beyond repair. Does anyone know where I can get ahold of a set or will I be forced to make my own.
You should be able to find them pretty easily, either from a junk yard, mopar or an aftermarket supplier. If you want to go the mopar route, let me know and I can get a quote for you.
Ben
I would stary out of the junk yards, junk is all you will fine. There are many companies out there that make replacement panel s to truck and car bodies. They pretty much know the problem areas and make patch panels that you can purchase and weld in. Some areas come in several sizes so you can get one that is right for your rusted out area. JC Withney has them in there catalog, but I would do a search for "Body repair panels" or truck replacement panels". I have seen several different places that sell just such panels.
As far as all of my searches have shown the only thing that you can buy is the entire back corner, and not just the piece by the rocker panel. Fiberglass and bondo worked just fine
