This was a busy weekend, I got several things installed, including more Thermo Tec insulation in the cab. Since I was also installing a new stereo, I removed the seat (yes front and rear), and went on an insulation rampage. I used Dynamat spray on noise suppression in the inter door panels. This took two full cans and allowed me to get all the nooks and crannies, it also serves as a great rust proofing. Then I applied the Dynamat matting to the insides of the doors, and around the speakers. Between the door skin and the door panel, I applied a sheet of Thermo Tech's cool-it super insulation. It worked great, and I had no problem getting the door panel back on.
To the back of the cab, I insulated from the rear window down to the floor. In the b-pilar area (extended cab area), I insulated the cavity and applied the Dynamat matting as well. While I was there I covered the rear flooring area as well, most of which got two layers. I also applied an additional layer of Dynamat under the passenger side floor. The result was a very quite cab, the outside noise is dramatical reduced. I had done the front area of the cab a week or two earlier, and now with the whole cab done it's very nice. I would recommend anyone that likes to talk or listen to music while in their truck, to take the time to insulate it. The only area I have left to do is the hood, their I will add a single layer of the Thermo Tec super insulation to the back of the hood liner. I ran out of material this weekend, but will have more by Monday. I have not had time to go very far since the insulation was add, but the difference is very apparent.
