2nd Gen Non-Engine/Transmission Cab Mounts for 1996 Dodge
Does anyone have information on replacement cab mounts for a 96 Dodge. The front mounts have rotted and the front of the cab is sagging and pushing against linkage. I have checked with local Dodge dealerships and no one has them. Thanks.
B. G. , thanks for information. I checked it and they are the bushings. I need the actual mount that attaches to the underside of the cab to the bushings.
Fab time... ... ... .....
^^^^correct. I am in the same situation. Mine haven't failed yet, but they are rotting away. I have looked everywhere and they are not available. You will have to fab something up or get a good set from a donor. I think a simple section of large diameter tubing sandwiched between two plates would probably be a good starting point. Think large scale oreo cookie, the tubing is the "stuff", the plates are the cookies. Clear out the rotted stuff, fix the floor if necessary and slide the new mount into place, tack it to the floor???
