Im building myself this newer service truck
http://saabpics.nailed.org:3000/gallery/jak/trucknewfender
I pulled the floor mat out & pressure washed the inside of the cab & found a few rust spots a couple of which look like they may be a common problem this is where the floor meets the transition to the firewall at the kick panels just below the sorta oval shaped plastic plug in the kickpannel especially on the drivers side I should have no problem cutting & welding in the flat spots of which there are like 2 spots Ill have to cut out like a 4 inch square & weld in pieces but the area I mentioned will be a lil more difficult its not real bad but I was wondering if this was common
thanks again
JAK
thanks again
JAK
