I have a 99 3500 extended cab and I think it needs a new reostat that controls the temperature of the air while on heat or AC.
If I have the AC on and turn the temperature knob all the way to cold I get ice cold air. As I turn the knob towards heat, nothing happens until I get almost half way around at which point the air goes from cold to quite warm. From there, if I keep turning the knob towards the hottest setting, the air keeps getting hotter as it should. If I then move it towards cold a couple notches at a time the air will gradually get cooler but about a 1/4 turn before getting all the way to the coldest setting, the air goes back to ice cold.
This control is working the same whether I am using heat, AC or vent. In fact, with the truck off you can hear the electric motor react as described when the knob is turned.
This issue seems to have coincided with the replacement of the AC evaporator core and the heater core. The only thing that could have impacted this is that I took the temperature control motor off of the duct/housing. Inside the plastics of the motor housing is actually a little electric motor. I could have put that back in up side down but I can't see whereas that would even make a difference. It is just an electric motor with two contacts and if this was a problem I would have expected the motor to think hot was cold and cold was hot.
My guess is a bad reostat/temperature control switch. Any other opinions or things it could be?
Thanks
Thanks
