CAC pressure test setup (for all gens)
Online source for cheap $$$ FASS filters?
Mitusa Mechanical Lift Pump! It Rocks!!!
This was specifically for a 3rd gen since on the stock turbo location, things are so tight. but will work well for a 2nd or a 1st gen.
The part is a 4" OD PVC end cap. standard air compressor adapter. and some sort of sealant. In my case it's some high pressure thread lube/sealant for gas lines that my GF's dad gave to me in a bucket of flammable/non-flammable liquids.
Also, on a 3rd gen only, you should consider some sort of "catch" or barrier between the cap and oil filter. I've dented one good enough that you'd want to replace it :) Think "safer barrier" small rectangle box with some paper towels stuffed in it should absorb the PVC popping off.
The rubber piece between the turbo and PVC is from my AFE Stage II kit that I used for the air filter. The problem with this is it doesn't hold the PVC in place well over 25psi (hence my knowledge of a dented oil filter. ).
Getting the air compressor fitting in. I just drilled, but didn't tap the hole. Since it's plastic, the fitting did the tapping :). . smeared sealant all around and let sit for 24 hours.
I've checked mine and finally solved my air leaks up to 25psi. We'll see later today if the gauge shakes at 50psi. If you wanna pressure test more then 25psi. figure out a way to strap that pvc in place around the turbo.
On 1st and 2nd's you need a protector for the alternator. It does come out with a surprising amount of speed. ;)
For basic leak testing, or stock components, 20 psi is plenty.
I still have a shake at 50psi. not as bad as before... so I might one day rig up something and see where it might be... I bet the boost boots are leaking at higher pressures, they are old and worn a little.
I've been out of plumbing a few years and can't remember the name, but they make a coupler similar to the rubber fernco that has a metal band full length all the way around it. It will hold much higher pressures than the fernco.
DS, I've seen those, I think they're Fernco too. The rubber isn't the problem, usually the adapter won't stay on the turbo at higher psi. :eek:
