merrick,
Doesn't your truck weigh a tad more than Katmans?
Originally posted by KatDiesel
Next time on the street remind me to turn the box up![]()
I'm trying to make arrangements to cometo the March 15th DFW dyno day... ... ..... don't suppose you would be going again would you? Did Floor It help you out with what you needed?
merrick,
Originally posted by Sled Puller
merrick,
No doubt he outweighs me, my weight with just me and 1/4 tank of fuel is 6500lbs. That day with John, the toolbox, the rest of our junk and full of fuel I have no doubt we were at least 7000 to 7200lbs.
I don't think I ever turned the box up past Level II if I recall correctly?
Merrick i don't remember the exact times but I think you were mid 9's in the 1/8th by the end of the night. And yes I hate lag.....Although if I make it to dyno day I'm gonna put on the bigger exhaust housing to see if it will help out on the dyno regarding the peak power being off its range.
Originally posted by curatchko
Okay okay okay... .
I'm breaking down and buying the update kit, valve body and converter..... yeesh!!!!
So much for my tax return!!!
I could not have said that better myselfOriginally posted by Morphious
The auto transmission confounds me, I bought my 99 with the 5 speed, I just had it rebuilt 981. 00 parts and labor, it had 160k miles on it and the 3rd gear syncro went out. I am on my 3rd clutch, but the stock clutch lasted 60k miles, and the second clutch lasted 90-95k, I forget the exact mileage of install and destruction (I blew the center up out, and believe that to be the results of the pilot bearing disentegrating on me). 100k of those miles have been run with DDIII's and the TTPM on #3 setting. With this setup, I pulled trailers sometimes weighing in at 30k lbs during hay season, not quite sure how much my tractor weighed, but it's a 4010 industrial with a frontend loader..... not light by any means... .
What I can't understand is why even buy an auto? To pull heavy you have to invest serious money in them, to modify the engine you have to invest serious money in them, the only advantage you get is in drag racing.
Morph.
Morph.
Originally posted by SlyBones
Well I can think of 2 reasons
1. Seattle rush hour traffic
2. I am friggin lazy
So as soon as I get home from work, I should throw in a few pushup and a few crunches and I got it coverd? Hhhhmmmm..... See transmission threads can be useful.
