I just bought a field-strength/SWR meter from radio shack today to test my new Uniden CB. I have a K40 mounted on top of my headache rack, and the cable running under the truck to the engine bay, through the firewall into the cab.
I tested the SWR on ch. 20, 1, 40, and 19. The highest I got was a 1. 3. So, that checked out great. But, when I went to check the field strength, I could barely pick up any signal (scale is 1-5 on the meter, I could barely get a 1. 5 about 10ft. away) standing anywhere within the 25ft. circle required.
My truck was parked away from the garage, facing east, on a slight incline, basically out in the wide open. I've never tried to test this before, so??? When I stood in the bed of the truck, level with the ant. about 8ft. away, I got a 4 once. Got down, walked around the truck again and never got above a 2 anywhere close to the truck (in the 25ft. circle again).
I thought my ground could be bad on the headache rack, since it is sprayed with bedliner, so I moved the mag. mount ant. to the roof of the truck for a test. Still nothin' (no improvement).
How can my SWR be so danged good, and my field strength be so weak? I thought SWR tested how much % of signal was getting out. So, with SWR so low, why can't I pick up more signal on the field strength meter?
