OK, I'll never do that again! I'd rather pay the $265 or so and let some Dodge tech gritch and cuss his afternoon away. There's 6 hours of my life Ill never get back!
So, for those that absolutely must save the couple hundred bucks in labor costs (like me)... I ended up removing the air hose from the intercooler as well as the port battery (drivers side). That gave me just enought room to pretty much be able to do... nothing. I ended up buying a round headed 5mm allen wrench, and a 1/4 drive 5mm socket and with the help of a hack saw, I made a round headed 1/4 drive allen tip for my ratchet. As another member posted somewheres. . an 8th inch turn and the bolt busted loose. I was able to (with great manipulation) remove it by finger tip persuasion. Feeling very proud and accomplished, I grabbed my flat prybar, which all carpenters worth their weight in salt, have on hand, and popped that old sensor right out! Piece-of-cake! WooHoo! That is just about the time that life as I knew it... . began to suck. I dropped the new sensor atleast 10 times just trying to get it in the hole. After that, it was time for the install-the-bolt trick. That was about 15 minutes of colorful outbursts of excitement and delight. finally i got it in the hole and started. Now, if I can only seat it by hand and not have to use a wrench... . your kidding right?!?! I had to use the socket wrench, and could only get 1/32" turns on the bolt before I ran out of wrenching room, maybe 1/64th inch turns, but, I don't want to sound discouraging or pesimistic. about an hour later, the bolt was in. I put the rest of the truck back together and found I no longer cared if it worked or not. I proceeded to the comfort of a chair in my airconditioned kitchen and proceeded to enjoy a very fine micro brew from Vermont. I will test the truck and report back later... like... after I care again!
