Details here: TDR Privileges
the bolt on is definitely better for high performance high rpm usage, the press on gear is ok for a mild or low rpm truck, i am going back together with the bolt on kit from f-1 and the helix two cam... hope this helps and maybe someone else will chime in...
yes they are keyed in place. I am running the pressed on also. I would have opted for the bolt on, but due to parts availability and short time frame notice, I was unable to get the bolt in set up.
