Thanks a bunch! I recorded it kinda half joking around with my little brother, so I'm talking with some of our "funny" grammer. In the begining of the video I ask him "You has teh records?" (no typos there, that's how I said it. We joke around like that. . )
R&R'ing the lifters is a long stressful process, much easier without the head on. So, do it with the head off.
If you can, I'd stay with the OE tappets, but if you have alot of miles, then they should be replaced with the cam. (I'm not sure if the helix cam mandates you replace the tappets or not... . )
Just use some wire and cut the dowels you used to hold the lifters up into about a 3/4" or 1" section, where it's tapered off, and drill a 1/16" or so hole through the dowel and run the wire through the dowel. (If the dowel is not cut short enough, it will be very hard to "fish" the tappet back up into the correct hole in the block.
What you are looking for is a little stopper looking thing plugged into the tappet and about 12" of wire extending from that.
Use some metal fingers, I'm not sure what they are really called, but they are about 30" long, kinda like a tightly wound spring with a hard metal rod in the middle. When you press the little buttton on one end three little fingers extend and can "grab" something, when you realease the button, the fingers retract and pinch onto whatever you are trying to hold onto. I call it a "thing longer" (from a TV Cartoon called Futurama), but I don't know the proper name for it.
TO get the OE tappets out:
Take a 2. 5" pipe and cut it in half. It has to be thin wall. A PVC pipe will not work, the walls are too thick. I used some aluminized tubing from my local muffler shop. You want to slide the pipe in where the cam was, and pull up a dowel rod and unseat it from the tappet. The Tappet will fall onto the "tray" you made (the cut in half pipe). Then work the tray out and collect the tappet, repeat 12 times. Tappet 12 is the most stressfull because it's way back there, you can barely see it. It's easy to drop off the tray.
To get the new tappets in:
Take your re-modified dowel rods (1" or 3/4"), and wire, tapped into your tappet, and lay them in your tray, then look down from the top of the block and with your "thing longer" (somebody help me out here), reach down through the pushrod holes and fish up the string and tappet. Be careful because, as I learned, there are 3 holes per cylinder, and only two of them are for the tappets, the other hole, I assume is for an oil drain.
Once you get the tappets fished up just use your clothes pins to hold up the tappet/wire.
You need to make sure your dowels are firm, so they won't drop the tappets, but not so tight so that when you yank the wire, the wire and dowel come out, and that the wire doesn't just rip out of the dowel rod. That's no fun, because by the time you have to yank out the dowel rods from the tappets, the cam is already back in, so, you have to put all the dowel rods back in, yank the cam back out, get that tappet out, and fish it back in with a new modded dowel. Quite the hassle.
Other than that, just try not too think too hard about dropping a tappet. If I understand correctly, you have to drop the oil pan to get the tappet out, and to do that requires lifting the motor up slightly, but, I could be mistaken.
Hope that helps. It's late, and I may have left something out.
Merrick
