Anybody know how this thing works. I get a code referencing the sensor. When it acts up it misses noticably sometimes worse than others. Sometimes it is really bad. Changed out the sensor and no better. I had already unhooked the Juice before I changed the sensor so it doesnt seem to have anything to do with that.
Anybody have any ideas on what to check next. The sensor looks like a magnetic sensor or something. Is there a tone ring it is sensing? Could it be messed up and if so how do you change it out. Any other ideas on it would be welcome. Does anybody know if the sensor is read through the pcm or the ecm? I am totally lost on this one. I dont want to just start throwing expensive parts at it nor do I want mr mechanic doing the same thing.
The only other codes I have I can explain and have had for quite sometime as in a couple years (grid heater circuit 2, lift pump voltage which isnt hooked up due to my rasp setup)
