Engine/Transmission (1998.5 - 2002) Cam sensor / Crank position sensor.
Engine/Transmission (1998.5 - 2002) Drag racing hard on 6-speed
Engine/Transmission (1998.5 - 2002) hesitation ?
Does anyone know the best place to get a Rpm reading on the 24V trucks. I would assume it would be the Cam position sensor because I think they quit using the Crank position sensor in 2000.
And do you know the Values or how many Pulses to expect per revolution?? Thx Kurt
Kurt I know the Blue chip takes it's reading off the vp44 (Acurate as 1 RPM ) and I have checked mine against the "Factory tach and found it to be dead on until 2800 then the needle tach gets slow
