cam shaft wiring diagram
Manual transmission specialist in NC
Estimated power?
I had a code for cam shaft position sensor failure. when trouble shooting the wiring I have found that the wires in the plug do not match the wiring diagram I have from Alldatadiy Does anyone happen to have the wiring diagram showing the Cam Shaft sensor and C1 and C2 at ECM they could share?
its just a two wire sensor, is it not?
I would just temporary connect it and see if it works.. if it doesn't swap the wires.
Of course but I replaced plug and as this is not my first rodeo I was careful to plcae new plug wire as old were and symptoms are the same you would like to be able to double check yourself but I do appreciate your help.
what is the symptom? the CEL or is it drivability?
