Camber adjustable????
Pictures of 3rd gen tire and wheel combo's???
3.73, 37's, g56 What do you think?
I was reading an old post where someone said the camber on his 04 truck was not adjustable unless you install ball joints with an offset. I have an 04 truck.
Is this true? It looks like I have a problem where my front tires are wearing on the inside & according to some wheel alignment literature I have read, an improper camber is the problem.
Why would Dodge make the truck where you couldn't adjust the camber & then building the front end so it wears out tires long before their time?
This just doesn't make sense.
I am taking it in to the dealer tomorrow to have them look at it.
Big Rig
I just had a front end alignment on my '06 at LesSchwab. If the '04 is the same, then here's what is adjustable:
Front Left and Right:
Camber
Caster
Toe
Front:
Cross Camber
Cross Caster
Total Toe
Rear:
Thrust Angle
Not adjustable:
SAI
Included Angle
Turning Angle Diff.
Cross SAI
Cross Turn Diff.
Rear Left and Right:
Camber and Toe
There are specified ranges for each, including those settings that are not adjustable. You what those too?
Thanks Skipro3,
I will take your post with me to the dealer. I just noticed that the guys post that I referenced had a 4X4 & mine is 2x, so maybe that is the difference. I just hope they can fix it so I can get more wear out of these tires.
Big Rig
