I have an issue where the alignment shop says they can't bring both casters any closer than 2. 5 left, 3. 3 right caster with the camber at --0. 1 on both. Obviously the cross caster is at 0. 8 degrees.
I was wondering, on the upper ball joint, supposedly there is the eccentric to adjust the camber. What is the maximum degree difference that rotating the eccentric would achieve?
Knowing the dynamics of an offset, theoretically there would be two points in the 360 degree rotation that the camber would be at -0. 1 . Say the eccentric had an effective change of 1 degree, Would the fact that the camber was achieved at one of the points that it is at the wrong point for the caster explaining the almost 1 degree cross caster?
Brian
Brian
