So I spend all the money to replace and upgrade everything in my frontend and now take it to an alignment shop (finally). Everything is new with less than 500 miles on it. I also take them the very specific specs I want it set to. Ram steering specs
They call a couple hours later to say the truck is on the rack and the quoted $65 alignment will now be $330 due to the fact it needs offset camber bushings. I tell them to forget it and just park the truck back outside.
I was going to spend money for adjustable camber balljoint bushings when I did the balljoints, but was advised not to waste the money then (less than $50). Now it looks like I should have ignored that advice.
How many of you guys have had to use offset camber bushings on your truck?
