camper slide in guides? what to us?
which gooseneck hitch to get?
Slide-in weights?
i want to put in some camper slide in glides
on my bed , maybe a drop in bed frame
on the sides . so camper does not sit on it.
any ideas , places to buy
i hit tail light once and have small dent
on fender inside of bed from camper
sides as i slid it in.
thanks in advance.
bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
Check the guides that Lance camper uses.
1995 2500 5 spd US Gear 2 speed,PackBrake, bombed,big turbo, injectors CUMMINS POWER!!. 2001 ETH 3500 PackBrake, gagues,otherwise stock. 1972 "1066" International Harvester 414 ci diesel pulling tractor, big pump,turbo and injectors. Alcohol injection,BINDER POWER!! .
GONZO
I purchased the guides from Lance. There are 4 of them. If you want them to help you guide the camper into the bed they are not much help. You have to raise the camper a few inches higher than the bed as the guides are about 4" high and slanted down towards the inside of the bed so when you lower the camper into the bed it will slide over if you are not centered. You still have to back up like you are sighting a rifle
I have not yet done so, but I was thinking about just putting a line down the center of the bed. Then, just put a mark on the center of the camper and align the two as you back in. I'll probably have to break something before I actually get to it though.
David Dressler
2001 Driftwood 3500 Quad Cab 4x4, 155 inch WB, HO Cummins (ETH), 6-Speed (DEE), SLT+, 3. 54 LSD, Camper Special, Trailer Tow, Heated Leather, Sliding Window, Jacob's E-Brake, Rhino Liner, VDO Vision (pyro, boost, engine + diff. temp. ), Weather Guard Diamond Plate Saddle Box, Tork Lift camper tie-downs, Mag-Hytec, Mopar Tow Hooks, AND functional Halo light!
Bigfoot 3000 10. 11 Slide-in Camper. "Do it in a Dually"
a painted line may help
i lower drivers seat back site out bk window
and eye edge of camper straight on.
maybe a angled drop in frame guide
is the way to go,angeled so to drop in
dont like the 4'' higher one, may have some made , bill
5 antenna's
