Can any body give a review of Genos radiator?
STOCK RIDE HEIGHT
Left headlight out, so where is the ground?
When I replaced my oem in 2018 with the stock aftermarket from local parts store made by OSC, Geno's did not sell any. No overheating issue to date. However wish I had held onto the old 3 core one too.
This young man on youtube likes getting all aluminum radiators through some place on ebay for his 12 valve.
Looks like a standard OEM replacement, will have the same specs thoug.
Quite funny. My original radiator was three row with a core 2 3/8 inch thick and made of what appears to be a copper/aluminum alloy. It also had a reinforced framework. The original lasted a long time, something like 600k miles and I never had an overheating issue when towing heavy. When the tank started leaking I found that no one repairs plastic tank radiators so I bought an "OEM replacement" from Mopar. It was two row with a 2 1/8 core made of shiny aluminum. It did not have a reinforced frame and performed poorly. It also lasted less than 200,000 miles. Please tell me, what is a "standard OEM replacement" and why would I want a "standard OEM replacement"?
If you notice neither radiator had the studs on the top for securing the battery cable. I ordered one like it on Amazon. It was three row aluminum and pictured it showed the studs. When it got to the house there were no studs. I didn't even take it out of the box.
Noted.
I recall getting little information that helped with the same question 3 years ago.
Same guy talks a little more on this vid about the radiators he likes and also shows how to fasten the battery cable.
OEM means what you get buying a part from MOPAR.
Apparently Dodge changed it through the years.
Same with my '98 GC Limited at Home, no Copper core available anymore, just Aluminum.
An "OEM replacement" should be equal in quality, or better than, the original part regardless of who sells it. The point was there are no specs for an OEM replacement, so there is no way to compare. Buying Mopar isn't a guarantee of quality or adequate specs.
Since it was a Genos product I was optimistic.
If I was flipping used trucks I might do a hack job too. I want that cable secure, not just attached in the middle. In addition, every all aluminum radiator I found on E-Bay and Amazon had comments to the affect that the shroud didn't fit correctly, the drain wasn't accessible, and other fitment issues. If no one responds who has bought one from Genos I'll call them on Monday to get the specs.
Sorry to hear about the Icebox radiator failing so soon. I remember when you had this made a few years ago and that it was providing very good cooling and the build looked good when new.
Still using original radiator in my 1999 and not looking forward to trying to find a quality replacement if or when it fails.
Any feedback on TDR from members using the Mishimoto radiator? It appears to be good build quality and an adequately sized 3 row core, but it is pricey. Very similar cost to the custom Icebox radiator.
Going to follow this thread to see what radiators might be a good solution and hope you can find a good quality radiator soon.
Michael
I'm curious about the Mishimoto as well. I know I'm due for one soon. My 14 year old Auto Zone radiator is looking rough.
I have installed the one from Genos. So far I'm happy. The core is 2 1/4 inches thick, the same as the original. Two rows instead of three but the tubes are larger. It was a perfect fit and all the hardware is correct. Of course it will be a few months before I can test it's ability to cool in 90+ degree weather with a camper in tow but I'm pretty sure it will do well. IMO the price was right.
China
Edit; So was my genuine Cummins fuel pump, also bought from Genos. My failed radiator, that cost more than 3 times as much was made in the USA. Despite their fancy website and celebrity reviews the product lasted only three years. When I called them the nice lady on the phone said that if I sent it to them they "might" be able to repair it. The local radiator shop that repaired my all metal '54 Ford radiator said "no way". I'm not willing to pay the freight from TX to OR for a radiator that weighs 56 pounds (that is NOT a typo) on a maybe. I do have it packed just in case I have room for it the next time we go visit the grand children. The trip to Sweet Home from there is only about 50 miles.
