Can any of you guys keep a right front tire on your truck??
Gorilla didn't put on my oil filter
1995 auto trans changes needed
My buddies and I all have these trucks about nine of them now! Some of us (about 4) of the 12 valve trucks cannot keep a right front tire on these trucks they EAT THEM, the problem is this you look at the tire and we are all running BFG Mud Terrians and every other lug is cut down and shaved off from the back of the tire toward the front, kind of a backward cut on every other lug?? What gives these tires are getting expensive!!!
94' 2500 4x4, 2. 5" Skyjacker, tweaked afc & pump, BIG plate, no muffler or resonator, 16. 5x9. 75 Weld Rims, 33x12. 50 BFG Mud Terrians, 60 psi boost gauge, pryometer, J&J Stainless Steel rear 10" drop bumper w/backup lights, Westin pushbar, PIAA 90 Pro series lights, Weatherguard toolbox 27"
You are describing a "Feathered edge". The most common causes are excessive toe-in. Check your alignment. It is also quite common for large tires to magnify the problem. I got 65k on my original tires, and currently have 40k on present tires ( which are 2 sizes oversized ). Never have had any scuffed edges. I rotate the tires every 10k and check the tire pressure every week.
Good Luck
RK
98 Properly Valved 4x4 SWB QC ISB A/T Metallic Red w/ tan cloth interior, DC nerf bars, DC two piece mud-flaps, 275 h. p. injectors, Monroe Gas Magnums, Armor Tuff spray in bed liner, Goodyear Wrangler ATS 285/75r/16, BD Heavy Duty Valve body. Walker 21468 thru flow muffler,Cobra 29 NWST CB. American Racing Wheels.
This is not a really "featherd edge" as you would call it, it really weird, my mud terrians have lugs on the outside and every other one is like backward cut. It's the total opposite of what you think the tire would cut it it back cut like from the back of the truck forward on every other lug. Still lost happens so quick if i rotate the tires it just eats all of them if I run the front ones only on the front, I seem to get realy good milage out of the tires but I have to buy new front tires about every 20,000 What gives, I have a brand new LINDSTAD alignment track bar and it is tight in adjustment!!
Got 10,000 on my BFG's, same thing is happening to mine. Maybe it's how Smokin Cummins and us southern Ohio boys drive them while SMOKIN out the Power Jokes !!!.
"Blackdog" 2001 Cummins, 2500, 4x4, QC, SWB, LSD, Auto, Agate Leather, Every Option Available, 33x12. 50 BFG Mudder's on 16. 5x9. 75 Weld Super Singles, 2. 5" Skyjacker, Dee Zee D-Plate Toolbox, Bed Rails, Tailgate Protector, JVD Torque Enhancer, 425 hp Injectors, Isspro Boost/Pyrometer Guages, Boost Module, HX 35 w/12cm housing non-wastegated, Straight Pipe, K&N, Coming Soon... high stall Pro Torque Convertor, Valve Body.
"Dodge Makes It, Cummins Shakes It"
I'm just keeping my fingers crossed on this potential Goodyear recall. My Wrangler AT's are garbage. If I took them off and threw them out they wouldn't last ten minutes in the trash. They have worn great, I rotate, maintain pressures, but 3 out 4 have failed road force test, they can't be balanced! I'm saving for some Michelin LTX A/S.
I have not used good /year in some time now.
Good /Year stands for = Good for one year.
I either buy BF Goodrich or Michlin, Cooper makes a good tire as well they are limited on thier sizes tho.
Good luck
Chris
I guess in this case you DO NOT get what you pay for. Good/Year costs = BF Goodrich
Happy truckin
2001. 5 2500 Intense Blue Sport 285-16 mounted on 8x16 Baja
6 speed 4:10 limited slip heavy duty everything, Cab lights,
no heated seats or leather.
