Snoxracer said:Blow by is what happens when a Powerjoke or a Undurablemax trys to keep up with a Cummins!You Blow By them!!! :-laf
Snoxracer
jelag said:Let me add to the post that Tim posted, with respect sir... .
As the engine wears (rings) more and more of the gasses at the time of the explosion will go past the rings... this washes down the cylinders with some high pressure gases and will force these gasses with some oil out the breather system... . the more wear on the engine the worse it gets... .
He's right on the money with a puff of smoke when the engine starts... as the engine cools... the heated oil will drift past the valve guide oil seals down the guide and can puddle on the back of the valve... as the engine starts it takes in this oil and burns it... once the engine heats up the seals do a better job sealing..... and what does go by is in smaller quantities... ... in most cases, you can put the piston to TDC (top dead center) pop off the keeper and spring and replace the old and hardened valve guide oil seals... they get hard and brittle with age... . however modern engines usually have valve guide oil seals that go the life of the engine.....
Hope this adds a little... .
gtobey said:Jason, even though it is warm outside, the block temperature and combustion chamber are cool compared to their normal operating temperature. If your compression is near the minimum limits, then the unburned fuel will appear as a blueish smoke and smell raw and sometimes burn your eyes and nose. Oil that is sucked into the combustion chamber from the valves upon startup provides an additional "puff" of smoke upon startup but subsides quickly. The unburned "raw" fuel gradually decreases until cylinder temperature helps overcome it. Your turbo is not leaking oil into the intake is it? That is a source of oil to cause the blue smoke upon startup. I would hope that your rings and valve guides are not worn in only 40,000 miles.
