After changing my lift pump, the check engine light came on and it is 'P0216. ' According to my Quick Check II scanner, it has something to do with 'low fuel pressure. ' The lift pump now reads 15 #PSI @ idle, but when I first started the engine it only read 5 #PSI 'till it ran a few seconds.
The scanner shows it is an 'inactive code' and is no longer being actively set, just being stored. I tried disconnecting the batteries over night but it's still there.
I read that I can remove the air box to get to and unplug the ECM and PCM for a few seconds and that will clear the code.
If true, do I disconnect the batteries first or not? Thanks,
Bob
Bob
