Kirwin: If the headlight switch is the same style as the second gen trucks there are two very simple ways to do this for less than a buck. Take out the fog lamp relay, there should be three slots going in one direction and two slots going the other direction. take a 1" piece of 14 gauge wire and two male spade connectors, make a jumper and jump it it across the two slots going in the same direction. test the lights/foglights and make sure it works. If it does, a cleaner looking way is to solder a little jumper wire between the two pins on the realy itself. What i do is strip a little piece of 14 gauge wire and tin it with solder, then pound it flat and solder it in place on the relay as a permanent jumper. Once you put the relay back in, you can even tell its there. I've done this to at least a dozen or so trucks. Worked every time.
