Can I Upgrade fass 150 pump to one with filters.
Changing power stearing fluid is a GOOD IDEA!
How good is the BULLYDOG torque dog module?
Dan
Another question for you. I am looking at upgrading to the filter setup yet, and am dealing with Mike on a trade deal. But your kit requires the routing of heater hose to the unit for fuel heating.
Fleetgaurd makes an electric fuel heater unit kit that comes with an adapter that goes between the filterbase and filter.
the fleetgaurd # is 3836029S for the kit.
Could I go that route rather than the heater hose to the unit for a much cleaner install?
Here is a link so others can see it. I called a couple fleetgaurd dealers and they are $200.
http://www.cumminsfiltration.com/pdfs/product_lit/asia_pacific_brochures/fleetschool08-2001.pdf
After visiting with Mike I have decided to use an aftermarket remote filter and housing and 1 of these. It will be roughly same cost as the fass with filter upgrade and will be a cleaner install when I am done.
Thanks for the help Dan.
i live in CT had no issues w/Fass pump filters without heaters this winter ,was darn cold! but not often below zero.
