The power driver's side door mirror on my 2006 RAM 2500 works partially. The mirror will move left-right but will only move down when the switch is pressed. The motor can be heard running, but the mirror fails to come back up without a little assistance from my thumb. The right side mirror functions normally. I suspect the problem is from dirt or corrosion, but I don't know if the unit can be disassembled.
Has anyone else had this problem and fixed it without replacing the whole unit?
Thanks!
Thanks!
