2nd Gen Non-Engine/Transmission can tracbar cause truck to pull
Engine/Transmission (1998.5 - 2002) 4'' muffler
For about a month I have noticed my truck is starting to pull right
going down roads in didn't use to pull. This is just cruising along at a constant speed and seems to be getting worse. If it pulled all the time I would think it was a tire but it is intermitent.
Can a worn tracbar cause the truck to pull sometimes and other times drive straight?
Thanks in advance,
Kent
Kent,
I replaced the track bar on my 1997 and it helped my pull to the right quite a bit. Prior to this, I tried alignments and rotating the tires. Nothing seemed to help as much as the track bar replacement. I know the track bar was bad as I was able to see movement on the end that attaches to the truck when having someone turn the steering wheel back and forth and watching from underneath (truck parked, brake on, running).
T-Bone
