Can u put factory heated mirrors on a truck that didn't have them from factory?
Test for steering problems
Power windows quit
I wanted to put dodge heated mirrors on my truck and wondering if there is wiring for them tucked away but not used. . ? or has anyone tried wiring heated mirrors themselves?
I did on my 95, had to run the wires and install a switch. Make sure your wires are of the proper gauge and you may thing about a relay in the circuit so that you don't fry the switch. Remember, anything that generates heat will draw more amps than just a light. If you're lucky, the wiring will already be there. For example, my 95 has manual windows but the wiring for auto windows is already in place.
I found some heated tow mirrors for my 2004 2500 and everyone is telling me that the wiring is behind the door panel for these... I also found a different climate control cluster, with mirror heat button under the a/c button... so if I add the mirrors and new cluster I'm assuming the mirror heat will function? Any help would be appreciated
