Can you run forever at the rev limiter???
Gentlemen
A friend of mine has a new Country Coach 40' pusher with the Cummins ISL rated at 400 HP and 1200 lb ft of torque and the Allison 3000. We were in Wa state and I had the chance to drive it. While on the road with me behind the wheel when pulling a 6 percenter he asked me if I felt it was sluggish and that it couldn't pull such hills in 6th. I said I felt he should be down shifting to fifth for such grades.
Soooooo a phone call to Cummins confirmed this and that the motor can safely be run at the rev limiter for how ever long was needed, and that it also helped with the torque converter's operation (allowing it to stay locked). My question is can the HPCR motor found in our Dodge Rams sustain this same operation (at rev limiter) for extended periods of time Cummins says it can. I guess with the motor right under your feet it only sounds like the motor is going to come apart
Mac
Gentlemen
Mac
