Dhuffman,
Mine didn't either till yesterday morning. I run the rears at 55 as well.
DBrooks, thanks for that info of 50 psi. Yesterday when I got home, I parked in the shade and late yesterday evening, I checked the pressures. Both rears were at 56 psi. I dropped the pressure to 50 psi. I noticed that the air in the tires was very hot. Probably because of the 100+ degree weather we have been having here in Georgia for the past month.
This morning, the TPMS reset itself as I was pulling out of the driveway. The pressure in both rears showed 45 psi. By the time I got to work, the pressure in both was up to 48. I credit the still hot pavement for the rise in pressure.
Anyway, all is well for now until the temps cool off. Then I will have to increase the pressure. Otherwise, I will be down to below 40 psi when the first cold snap hits.
Thanks for the help, guys. AH64ID's tip to check the door (which I had done) made me realize that the pressures have to be right for the system to work. It is unfortunate that the system doesn't realize when I tell it to go to Light Load, that I know what I'm doing.
