I've had my truck for 2 years with no problems with stock fuel system. I was reading 15 idle and 11 WOT. About 4 months ago, my FP gauge started dropping to 12 and 9. No problem, I'll just change lift pump, right? I changed to a brand new lift pump and filter. It made no difference. I then figured I had a clog in my tank pickup filters. My float bad bad anyway so I dropped the tank and replaced the entire $350 pickup unit. No change. OK, so I got a bad lift pump. I got it warrantied and still no change. I just killed my VP and I need to fix the pressure problem ASAP. I'm now idling at 8 psi and I'm not going to drive it until I fix it. Please provide some suggestions.
