Loren
My 2000 model 2500 sat four days in the heated garage. When I tried to drive it, both batteries were dead. After charging the batteries (I hope the Optima deep-cycle batteries really are deep-cycle. ) I found a slightly pulsating 5-1/2 amp. draw with the ignition off.
My troubleshooting has narrowed the problem to somewhere downstream, or inside, of the power distribution center (the box with the heavy-duty fuses under the hood). Removing the lead from the battery to the PDC cuts the current draw.
I tried pulling individual fuses, including the 140 amp. main fuse, as well as the relays. The current draw did not stop with any fuse or relay removed. It also did not stop when I pulled the Ignition Off Draw fuse at the driver's door fuse panel.
I have tapped the current downstream of the 140 amp. main fuse to supply power to a U. S. Gear exhaust brake and to supply power to a Painless Wiring secondary fuse panel. This was done by adding an additional wire to the stud on the fused side of the main fuse, not by cutting or piercing any wire. Disconnecting the wires to these accessories does not stop the current draw.
I have also bypassed the fog lamp relay with a jumper wire to allow fog lamp operation with high beams. Removing the jumper does not stop the current.
I'm baffled. The only thing I have done so far that has stopped the current is disconnect the red wire from the left battery to the PDC. Does anyone have any ideas or suggestions?
If I can't find the problem, I'll have to take the truck into my dealership, but I expect that they will try to tell me that my accessories caused the problem somehow. Of course, that's possible, but it doesn't seem to be the case. I'd sure like to fix this myself and would welcome any hints.
Loren
2000 Quad Cab, 4x4, short bed, six-speed: U. S. Gear exhaust brake, MileMarker Select Drive viscous coupling, Velvet-Ride spring shackles, Painless Wiring circuit box, Optima yellow-top batteries, Super-Glide 5th wheel hitch, Reese folding ball gooseneck hitch, Drawtite front hitch receiver, Tekonsha Sentinel brake controller, Westin nerf bars, Clarion sound system
1995 Standard Cab, 4x4, long bed, automatic: Firestone Ride-Rite air springs, torque converter lock-up switch, 4" cat-back exhaust, Reese 20K 5th wheel hitch, Reese gooseneck hitch, Hayes Micro Control trailer brake controller, 100 gallon bed-mounted fuel tank with 12 volt electric pump & fill nozzle, Swiss Cap fiberglass cap
Loren
