My original OEM batteries lasted 7 years! I never plugged my truck in at home, even when we had sub zero temps for 2 months straight. Not only would it turn over but did so strong and started within 3 or 4 revolutions. As in, instantly! Sadly enough, they gave up the ghost at a time when funds were thin, ok so they are still thin.
I ended up buying CAR QUEST batteries since Optimas are just way out of the question (then and now) and the Interstate Batteries that I have always used as replacements in everything were not available (in stock) right at the time I needed them. I bought the Car Quest.
Understand, I NEVER cleaned a battery terminal the first seven years. They were perfect the whole time.
The first set of carquest Batts started corroding my terminals and the battery hold down bolts within weeks. Winter hit a few months later and I had already cleaned the terminals 2 times and even used anti corrosion spray for battery terminals. The first cold snap and the truck wouldn't start. One battery, it turned out, had some internal problem. I had to replace it and eat a significant amount of "useage dollars".
The truck has never cold started as strong as it did with the OEM batteries. I still have HUGE amounts of corrosion that develops in only a few months! The nuts on the battery terminals are being eaten away, I have removed all the accessory leads to the battery a long time ago to rule them out. They were pretty well eaten away to nothing anyways. The terminal to my heater grid relays were eaten away inside. The battery hold down bolts are corroding away where they enter the battery tray at the bottom.
Am I crazy or could this really be from junk, crap Carquest batteries? Do you think I am taking my frustrations out on car quest or is my truck having a serious electrical problem that is feeding back to the batteries? I am not exagerating when I said it literally began with the new Batts.
If i replace them, who makes a good battery these days that don't cost Optima Dollars?
I also think i should replace the battery cable terminals now too. Should I just suck it up and buy OEM replacement cables from the dealer instead? I have never been thrilled about the quality of the metal they use on bolt on replacement terminals. Of course, I haven't done that in 20 years either.
That was a more "in my youth" thing.
Merry Christmas all.
Dennis
Dennis
