Can't see at night, HID Conversion
Will a W350 spring bolt into a W250?
Piston lift pump conversion
Everyone out there knows that the sealed beam headlights that are for our trucks aren't the best solution for lighting up the road at night. I added some KC lights to my bumper to help light the road and the local police and state troopers didn't like the blinding light in their rear view mirrors. I didn't want to loose the brightness of the KCs but I was tired of being pulled over for "Failure to dim lights. " Since I have a few friends who have upgraded to HIDs in their newer trucks i opted to do the same.
Here's a pic of the stock sealed beams
First I had to buy the H4 conversion, JCWhitney offers a kit for around $50 so I purchased that and then on eBay I found a company that sold the HID conversion kit for $88 with a 5 year warranty, can't beat that.
the H4 kit from JCWhitney
So I'm posting this thread for information for those who want better headlights without all the whillynilly of taking parts from a high end car and fabricating them to make them fit the first gen. Although I did have to cut the bucket that the headlight sits in to make the HID bulb sit in correctly that was the only fabrication I had to do.
The stock bucket
and the cut
the back of the headlight (why it needed to be cut)
Also, the H4 conversion headlights are a bit thicker around the edges so the 4 sheet metal screws that hold the light in place had to be a 1/2" longer to work but all the conversion took was 8 new screws and about 30 minutes of my time.
The final result
and also with the KCs
Now that I have HIDs I will never go back to halogens.
Which bulbs did you get? I read the 4100k are the best for light without glare. Anything higher is just bluer and more glare. There is a thread on 1st gen with some good links to info. I found the conversion housings on the Bay for $30, but haven't done anything yet.
I forgot to add that,
I have 6000K, they are classified as Diamond White which makes the road crystal clear, Ill see if i can get some good pictures lighting up the road. Im not sure about the glare, they are white as a sheet of paper, maybe a hint of blue if you compare them to 4300K bulbs which are yellowish similar to a conventional halogen bulb.
great fix even if its not broken. I have to hold a match out the window when i drive at night so maybe this will make the match unneeded. great post and another project for me tks.
