Last week my Wife called and said that the heater in the 02 caravan (3. 3L) had stopped working. Looked at it when I got home and found it was way low on coolant. Temp gauge was reading where it normally does and appears to be running just fine. Found the pretty major coolant leak where the upper hose connects to the thermostat housing. Easy to fix with a new hose clamp. So, I filled up the radiator again with coolant/water mix. After a while both the front and rear heaters again started to produce heat.
So, what I am concerned about is the possibiltiy that some damage was done like a head gasket or something like that. I took 3 or 4 days to purge the air from the radiator and suck in coolant from the overflow. The odd thing I am seeing is that the radiator hose appears to be rock hard after only driving around the block (i. e. engine still cold). I did a test this am and drove around the block. Upon arriving home the radiator hose was rock hard and stone cold. Oppened the radiator cap and there was no air in there and it did spew a bunch of coolant out onto the ground.
Am I being paranoid about the possibility of an internal compression leak into the cooling system? What should I look for as far as symptoms of an internal leak into the cooling system?
-Deon
-Deon
